That will may very well work.||Console|| said:then try and get a 45deg elbow vs a 90
||Console|| said:Just because it is memtest stable doent mean it is windows stable . Just belive us when we till you dont use blend when you are trying to find your max oc . If you really want to run it run it after you have every thing locked down as stable .
QuietIce said:A #10 bolt will self-thread into the average (plastic) 120mm fan hole (not the case hole), so if you're just attaching a grill to a fan use the #10. But I've no personal experience w/Yates so your results may vary.
I think the standard thread for case mounting holes (and probably rads, too) are #6 ...
QuietIce said:By "standoff" do you mean something like a spacer (short length of small tubing)? I found some aluminum ones at Ace but I think they're actually bushings. They worked great for spacers though ...
