- Mar 7, 2008
The same as on previous X platforms, cache frequency affects maximum memory bandwidth. It doesn't really matter if in use is DDR4-3000 or 3600 memory, bandwidth without cache overclocking is about the same. My CPU couldn't make more than 3300MHz on auto voltages. I will check later what affects cache.
Did you look further into cache? I'm about to see how far I can push mine as there are reports suggesting Skylake-X isn't scaling for high FPS gaming when overclocked, and I have to wonder if the cache is limiting it. I haven't looked at bios options, but I do note XTU allows you to set a fixed or offset cache voltage. It doesn't actually show what the stock voltage is though so maybe offset is safer... still, I think even if I go to ball park 3300 like you, that's still a significant boost over stock 2000. Let's see what bandwidth I can get
