- Thread Starter
- #61
You are missing IMC and cache dividers/speed in this calculation as memory speed and also stability on new platforms is generally limited by these 2 factors. Even though there can be "idle cycles" then there is a way to improve performance. This is why memory overclocking not always gives higher performance. It gives when all factors are matching. List of timings that are affecting stability and performance is really long not only CL, CR and one more. There are also additional settings, signal strength and other things.
I'm not saying that I've set perfect timings but that at these settings memory is fully stable and there are no issues with IMC or cache. In real, results are about as good as 3600 16-16-16 because limiting factors are somewhere else than in memory.
On older chipsets perfect timings were improving stability and performance. On new chipsets and DDR4 generally is some range in which it runs stable. Also some timings have to match for full stability but in most cases when we leave settings at auto then motherboards can handle that.
Other thing is that barely anyone cares if settings are perfect as long as everything is stable and performs well. We are not making any lab projects here or send people into space on these computers. Even then it wouldn't matter much. If I wanted perfect settings then I wouldn't push memory at 4000+.
What more, you never know if what you set in BIOS is really how it works. Motherboards are adjusting many settings behind our back but most users don't know that. In real some settings that user set wrong can be correct.
