Good morning,
I'm a new user - my name is Mawrecki. It's a pleasure to be here.
I'm a Scientists who is using Machine/Deep Learning daily.
I got a new PC for my job which includes all the components below.
I'd like to set it in such a way that it works with the highest efficiency and stability.
The thing is, that after XMP 2.0 activation in the BIOS, I heard three beeps.
Which mean I cannot use 3600 MHz frequency of my memory and I had to turn XMP off.
My set:
What I checked by myself:
After 14h of MemTest86 testing I got result:
The question is, what should I do to be able to use XMP 2.0 and 3600 MHz by default without any issues.
Thank you for all of your answers and comments.
Regards,
Mawrecki
My set:
- Gigabyte X399 AORUS PRO
- AMD Ryzen Threadripper 1950x
- NZXT Kraken X62
- G.SKILL 32GB (2x16GB) 3600MHz CL16 TridentZ - 2x
- 970 EVO Plus 1TB
- NVIDIA TITAN V
- Chieftec GPS-1250C 1250W
- MasterBox MB600L
- BIOS was upgraded from F1 (01/10/2018) to F2 (16/12/2019);
- I checked Qualified Vendors List (QVL) X399 AORUS PRO and I see that G.SKILL and 3600 MHz frequency should be supported;
- I checked X399 AORUS PRO User's Manual to support Quad Channel memory configuration properly;
- I was able to changed DRAM voltage by hand from 1.200V to 1.350V and multiplier to 30 what allows me to set 3000 MHz without beeps and errors;
Regards,
Mawrecki
