A lot of the x570’s storage specs look like this. Some may have more or less than others. Notice the availability differs based on the CPU Gen you’re using.Storage Interface
Integrated in the CPU (M2A_SOCKET):
· 3rd Generation AMD Ryzen™ processors:
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe 4.0 x4/x2 SSD support)
· 2nd Generation AMD Ryzen™ processors/2nd Generation AMD Ryzen™ with Radeon™ Vega Graphics processors/AMD Ryzen™ with Radeon™ Vega Graphics processors:
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe 3.0 x4/x2 SSD support)
Integrated in the Chipset (M2B_SOCKET):
1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe 4.0*/3.0 x4/x2 SSD support)
* For 3rd Generation AMD Ryzen™ processors only.
6 x SATA 6Gb/s connectors
Support for RAID 0, RAID 1, and RAID 10
Initial test at idle on a Giga Pro WiFi. 83 W on PS and 109 W using high performance in Windows PP. I do think that using a PCIe4 NVMe does something to power use as well since I didn't see reading this high previously. I also have my EK predator AIO in use which adds 10-15 W of power use
Right. The previous chipset used 4W... x570 for the consumer is an 11W chip. There is another (for HEDT?) which is rated higher at 15W.
But yeah, that wattage is about unbelievable if it's just the cpu (and board/drives etc).
Right... I get what hardware they have, but it's (the GPU) sitting idle, right? So does it really matter much when load testing the CPU only?
WPrime (download)
32M and 1024M
Power usage recorded at 1024M 50% complete, thermals recorded at 75% complete
3DMark has a CPU test, yes... but the CPU test runs without the GPU. The other tests use the CPU, like any other game.
But that said, the power testing is done using WPRIME which doesn't use the GPU at all... it just sits idle.
4 games was use for the reviews as well as:
3DMark Fire Strike (download)
FireStrike (1080p) Benchmark
Unigine Superposition (download)
1080p Extreme Benchmark
PCMark 10 Professional (download)
Express Benchmark
WPrime (download)
32M and 1024M
CineBench R15 (download)
CPU Multi
CPU Single
CineBench R20 (download)
CPU Multi
CPU Single
Handbrake (download)
Custom MP4 to MKV 4K conversion (details below)
AIDA64 Engineer (download)
CPU-Z (download)
HWMonitor (download)
