- Jan 9, 2006
i'm not 100% sure i need one yet but i've been chasing gremlins with my asus x99a usb 3.1 for as long as i can remember. i have a replacement for my new hard drive coming in and if it has the same issue as my first one even with a new cable in a different port i think it may be the final straw. i'm looking for a possible alternative to asus that will be rock solid for under $250 if it exists. i've read that asrock is good but the boards that support ddr4-3000 only have 1 pwm fan header and they aren't clear about whether they have intelligent fan control. what i need is...
4 pwm chassis fan headers with intelligent fan speed control. (it's not the end of the world if it only has 2 since i can get a couple splitters but 4 is better)
support for ddr4-3000 xmp profile
compatible with samsung 950 pro nvme m.2 drive
beefy enough to oc a 5820k to 4375mhz at 1.23-1.25v or so (not hard)
not have weird issues that drive me insane slowly over time trying to chase down bad components
thank you in advance
EDIT: the asrock taichi looks close but ddr4-3000 isn't on the list. will i still be able to set xmp? https://www.newegg.com/Product/Product.aspx?Item=N82E16813157719
also not familiar with asrock chassis fan control. is it similar to asus qfan?
