- Jan 1, 2008
Ok so I have a p5n32-e Sli plus and Im using an intel xeon X3210 at 2.13ghz. I want to overclock and if I increase it I just get a continuos single beep at star up that doesnt stop until you reset. Now I ring my uncle (im'a ignorant 14 year old ) and he says its to do with the RAM. the ram spec is
GeIL is proud to announced DDR2 800MHz, PC6400 800MHz supports CAS 4-4-4-12 with 1GB and 2GB Dual Channel Kits. These Ultra modules are hand picked for maximum FSB overclocking potential.
- PC6400 800MHz CAS 4-4-4-12
- 64x8 DDR2 BGA Chips
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- Lifetime Warranty
- 1.9V-2.3V Power Supply
I have the timings at 4-4-4-12 so would I have to change that at all to get the overclocking working.
I have a 550w (I think) Hiper PSU which is pretty decent.
Please dont get too complicated
Cheers, Tim
- Lifetime Warranty
Cheers, Tim
