Hi all,
I bought some new 2133 Mhz RAM (http://www.newegg.com/Product/Product.aspx?Item=N82E16820231476) which supports XMP.
Under CPU-z I can't see 2133. I only get 1066.1Mhz under DRAM Frequency, is this normal, am I looking at the right place?
Also, my NB Frequency keep cycling to various numbers: 1798.9, 3697.7, 3298.0 etc.. is this normal?
I went to the BIOS and selected the XMP profile 1 which lists the correct settings (Mhz, CL etc..) but I had the same result. Then, I went again to the BIOS and used the Profile but also manually set it to 2133 (as opposed to AUTO) but still nothing. Am I doing something wrong?
Thanks.
Alexisvx
Motherboard:
Asrock Z97 Extreme 4
CPU:
i5 4690k
CPU cooler:
Noctua NH-D14
PSU:
EVGA 750W ATX12V
Gcard:
GeForce GTX 650Ti Boost 2GB
RAM:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 2133
Case:
Fractal Design Define R4
Thanks.
Alexisvx
Motherboard:
CPU:
i5 4690k
CPU cooler:
Noctua NH-D14
PSU:
EVGA 750W ATX12V
Gcard:
RAM:
Case:
