- Dec 17, 2001
- Raleigh, NC
just built the following rig:
XP2100 rev B, AIUHB, 0248
Epox 8rda+
Slk-800, Smart Fan II
Antec True430 (power supply)
Zalman Northbridge HS (passive)
1x512 Corsair XMS3200 (low latency) w/ platinum Heatsinks
My first attempt at overclocking was to up my FSB to 166= 13x166= 2,157mhz
Upped CPU voltage to 1.7 (Vdimm, still default), RAM timings (default)
1) I ran CPU Hot Tester for 3 hours, no problem (will run for 6 tonight)
2) Ran MemTest for 3 hours, no errors
3) However, Prime95 ran for 1 hour with a "Sumout error".
My CPU temperature never got above 38C under stress. In fact with CPU Hot tester temp was 35C with fan wide open.
Questions
1) Is the Prime95 error a hardward or possible software(read that somewhere?) error?
2) If CPU Hot Tester runs 6 hours with no problems....am I stable?
3) I want to overclock further...what settings shoudl I change next?
4) What's probability of getting to 2.3 or 2.4ghz based on my results so far?
thanks
Mattlock
Epox 8rda+
Questions
thanks
Mattlock
