- Apr 22, 2002
- Folding@Home in Ball Ground, GA
I wouldn't say that Prime95 is useless, but I do think that it is over-used. I have seen several computers running all stock (default) settings fail Prime95, but these same computers work fine for weeks/months at a time under normal usage without any problems at all. I think you have to take into consideration what the computer is going to be used for, and what you hope to achieve as far as stability is concerned.
If you are building a gaming computer and it will run all of your games for hours on end without problems, then does it really matter that it crashes after 24 hours of running Prime95? I guess each user must decide for themselves.
