Nothing wrong with being ambitious....
I didn't manage 4.2... i reckon my RAM can't cope with it... will settle for 4.1GHz tho...
Edit: Also nttdemented.... Nice clocks and nice setup!! Welcome to the 4GHz club!!
Thats right duff.Yeh go with what CPU-z reads... its the most accurate
When vcore is lower than what it is set in the BIOS, that is vdrop... read what cpu-z says is vcore when IDLING. And when you put the cpu under load, vcore will drop again... that is vdroop... these values deviate from mobo to mobo and it is something to watch when oc'ing
If i have that the wrong way round please someone correct me... or if im wrong altogether... again... correct me!!
Thumbnail picturze plzzzzz.
Check vcore through CPUz...
To see your actual stock voltage, you need to run Coretemp, I believe it shows he VID right on there. 1.36v is the max for that chip for stock voltage, not your actual stock voltage.
AN E0 e8400 should get to 4ghz+ easily. You should hover in the 4.3Ghz range on air.
DO IT!!!!!!!
Good luck!!
1.5v shouldnt kill it bit i wouldnt use it for everyday use...
DO IT!!!!!!!
