allright it's time for a long overdue build! all of the parts are selected with a few choices for different items
and thank you, all you hardware junkies out there, nothing like the thrill of the build! I appreciate any and all comments
the old system is pushing about 8yrs old and the plan was to future proof it, it was
AMD Athlon XP 2000 1.6Ghz
2Gb Cas 2.5 DDR333
ATI Radeon Allin1 9800
350w Allied PSU
Assorted this and that
(but I had a capacitor blow on the motherboard and can only run it at 1.25Ghz, and it shuts off at 80% load)
For the new one the plan is also to futureproof a bit, my budget is $850
it purpose will be mid level gaming machine,, surfing sites with web 2.0 junk, occasional video and photo editing. and of course sitting there looking cool
Motherboard
Asus M4a87TD/USB
http://usa.asus.com/product.aspx?P_ID=nlWYrI9wlNIYHAaa&content=specifications
AM3 145w support
6 x sata 6Gb/1 x pata
2 USB3.0
NB AMD 870
SB AMD SB850
1 x PCIE 2.0 x16
1 x PCIE 2.0 x4
100.00
Processor
Phenom II 945 Deneb 3.0GHz 2gh HT 95W 140.00
HDX945WFK4DGM
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103809&Tpk=HDX945WFGMBOX
Ram
F3-12800CL7D-4GBRH G-Skill Ripjaws 120.00
pc3(12800) 1600mhz 2x2gb
7-7-7-24
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231279&Tpk=F3-12800CL7D-4GBRH
or
F3-12800CL8D-4GBRM G.SKILL Ripjaws 103.00
pc3(12800) 2x2GB
8-8-8-24
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231278&Tpk=F3-12800CL8D-4GBRM
Videocard
XFX HD-575X-ZNFC Radeon HD 5750 141.00
1GB 128-bit GDDR5 PCIE 2.0x16
720sprocs 750mhz DX11
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150448
or
HIS H577FK1GD Radeon HD 5770 157.00
(Juniper XT) 1GB 128-bit GDDR5 PCIE 2.0x16
800sprocs 850mhz DX11
http://www.newegg.com/Product/Produ...m_re=HIS_-_Radeon_5770-_-14-161-338-_-Product
Harddrive
WD6402AAEX 640Gb sata6 64mb cache 74.00
CPU Fan
ARCTIC COOLING Freezer 7 Pro Rev.2 35.00
92mm Fluid Dynamic CPU Cooler
http://www.newegg.com/Product/Produ...86134&Tpk=Arctic Cooling Freezer 7 Pro Rev. 2
Powersupply
OCZ Fatal1ty OCZ550FTY 550W 70.00
ATX12V v2.2 / EPS12V SLI Ready
80 PLUS Certified Modular Active
PFC Power Supply
+3.3V@25A, +5V@25A,
+12V1@25A, +12V2@25A,
[email protected], [email protected]
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
RAIDMAX HYBRID 2 RX-630SS 630W 62.00
ATX12V V2.2/EPS12V
SLI Ready XFire Modular LED
+3.3V@25A, +5V@25A,
+12V1@22A, +12V2@22A,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152035&Tpk=RAIDMAX HYBRID 2 RX-630SS
Case
Rosewill CHALLENGER ATX Mid Case, 50.00
1x Front Blue LED 120, 1x Top 140,
1x Rear 120, (NI) 2x Side 120mm
Bottom Mounted PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153&Tpk=Rosewill CHALLENGER
windows 7 home premium OEM 99.00
did find one thing that confused me though, on this page
http://www.cpu-world.com/CPUs/K10/AMD-Phenom II X4 945 - HDX945WFK4DGM (HDX945WFGMBOX).html
it states that "The fastest supported memory is DDR2-1066 and DDR3-1333"
now that don't seem right, will I not be able to use the 1600? or will it take some tweaking to get all the bus's, volts, and timings right? there is a future OC when it's time to do it and move to 2000mhz ram which the board states it supports with overclock
so do I have to really be concerned about this or is this just a non-issue?
also wondering about the cpu fan/ram/case wiggle room, the size of the cooler doesn't look like its a monster but with both fans I'm wondering if it wont bump the ram when all 4 slots are filled
price ranges from $805 low end to $845 high end
there is of course the worthless rebates and some ok promo codes to apply
once I recover financially from these purchases I will be looking into a nice 26' lcd at arounf $200
so what do you think? still would need to eventually pick up a sata cd/dvd burner and some kinda of decent kb and mouse. but for now the money nneds to go to core componants
again any comments appreciated and thanks ahead of time!
2Gb Cas 2.5 DDR333
350w Allied PSU
Motherboard
Asus M4a87TD/USB
AM3 145w support
2 USB3.0
NB AMD 870
SB AMD SB850
1 x PCIE 2.0 x16
1 x PCIE 2.0 x4
100.00
Processor
HDX945WFK4DGM
Ram
7-7-7-24
or
pc3(12800) 2x2GB
8-8-8-24
Videocard
or
Harddrive
CPU Fan
Powersupply
PFC Power Supply
+3.3V@25A, +5V@25A,
ATX12V V2.2/EPS12V
+3.3V@25A, +5V@25A,
Case
Bottom Mounted PSU
