Your Guide to Setting Up a HLDS
this is my problem..it say updating installation but it take very long time and it do not start the download...
can give solution???
WoW
ok ill try to enstablish the server on the next week ...
i on the boarding school !!^_^
sorry for the dealey but i just gave it up...
now i wanna to try again ...
>< now i must read all from the begining ><
now i have "new" computer(i have it almost 1/2 year) ^_^
with HD4870 card
dual overcloacked 3.0gHz
2k ram ... and more bla blah blah....you gott the point....:santa:
with HD4870 card
Let us know if you manage to get it working!
Wow so if i'm getting this correctly. I tested my speed on new york and chicago. I get 2000 kb/s upload speed. So i could run a left 4 dead server then?
My buddy has a spare machine he had talked about running a server on. dual core, 2 gigs of memory. So i'm guessing hes way above the requirements on the hardware side and he has the same connection i do (lives few blocks away).
Yeh 2MB up is plenty enough to host a server. With a dual core 2GB RAM, you could host probably 20-25 players rock solid. You are limited by the connection not the computer in your case.
i need help connecting to my own server. everything works and i can tell b/c other ppl are able to get in but i cant, everytime i clik to join it brings me to the loading screen and stays there until it says somthing bout connection lost. pls help
Are you playing from the same box or different? Have you tried any other computers? Try joining the game from the same computer that is hosting it.
First of all, great thread ps2cho. My friends cannot connect to my hlds server running on Ubuntu. I can connect on my lan. After port forwarding didn't work, I put the computer in a DMZ on my router. Still no avail. I even changed the port that the server runs on. Any advice?
Does the server show up in the master list? Find your IP addy (www.whatismyip.com) and go into the console and type
connect putyouriphere:27015
If it joins then it is a NAT issue with your router. If it does NOT, then either your router is not forwarding the ports correctly, or your ISP has blocked that specific port. Try a different port after you have tried the above too.
I cannot connect to my server when I connect using my external ip address while on my lan. I port forwarded 27015 and 8080 and still no luck. Maybe Comcast has something to do with it? My friends can connect to my website hosted on that machine via apache2. I use this command to start the server:
sudo ./hlds_run -game cstrike -autoupdate +maxplayers 10 +map de_aztec
and I receive no errors. I feel like I'm so close. Could it be defaulting to only being a lan server? All your help is greatly appreciated.
I looked over the pages but I didn't see anyone else ask this. I am running into a problem, and this is what my command looks like
Hey. I've been trying to install hlds on linux, but for some reason when i download the steam.tar.gz, set the permission and then put "./steam", it would say
bash: ./steam: No such file or directory
But i downloaded it and extracted it. Have any ideas?
first a thanx a million for the amazing thread for installation
i was running my server from past 3-4months and last month and now i cannot find my sv.last month i did sv_lan 1 and then sv_lan 0 and it showed, but now i tried the same thing and it wont work.well my sv was running smooth till yest evening when suddenly it stopped showing up.i tried googling and finding some answers but i got nun.
well this is how it looks when i start the sv in gui mode
Setmaster: Unknown command enable
Menu item 18 added to Menus Front-End: "Plugin Cvars" from plugin "pluginmenu.amxx"
Menu item 19 added to Menus Front-End: "Plugin Commands" from plugin "pluginmenu.amxx"
Connection to Steam servers successful.
VAC secure mode is activated.
And the same if i start in console mode then this is how it looks
protocol version 58
steam auth server
adding master server 69.28.151.162:27010
adding master server 72.165.61.189:27010
in both cases i cannot see the server unless i got to my favourits and see.what may be the cause.few people told that i might be missing swds.dll where as i have it.what is my other option here.i am using netgear router.no setting were changed.port fowarding was done since i said i am running my sv from past 3-4months..
Its connecting to the master servers fine...
Have a friend do "connect yourip:_port" (minus _...it makes a smiley when I do :port...see) in his console and see if it connects. If it does, port forwarding is NOT an issue.
well i myself can connect to it.well the port checker shows all the possible numbers u can think of are NOT OPEN OR NOT REACHABLE,suddenly this happened..once my sv was down i did a update in my router and then i saw the port thing if they open or not and saw only errors.so i am not sure if it had happend before the update or it happend after the update.no matter what in both condition i cannot open the ports.i used utorrent and it uses a port so i checked it by uttorent it self if it works and what i see is error though it is downloading and all.any clue
Okay, first thanks for making such a great thread. I am completely new to making and running a server over the internet and I have some basic question. I read everything you have written, and read all the responses but am still not clear on some things.
First I am looking to start a TS server. I am not sure how familiar you are with the Specialists but I'm sure you will know this stuff. First and foremost if I start this server, and run it through my computer with standalone mode will I be able to play it from the same computer?
And If I can play it on the same computer can I play it with the same account that is running the server? For instance if When I put everything in I have it running off of my account Player1, can I use the account Player1 to start TS and play in the server that I am hosting?
Also if I change my internet will that effect the setup of the server? I am in college now so if I take my computer back up to college will I be able to run it there also?
Thanks for any help possible, and try to dumb it down for me if you can lol
