so you're trying to update your server/ create yes?
it should be -update cstrike -dir * should be able to download and update fine. i've never had to use my U/P
sry but its not working......
still the same problem .... :
You have the hldsupadtetool installation exe NOT the actual hldsupdatetool you really need I know this sucks becuse well... You know Valve.sry but its not working......
omg this thread... ROX!
I have a file-server, but it's actually 2gb ram and a dual core... I was thinking about running something cheaper for Steam as I kinda didn't want to run it on my file-server, but maybe I will combine both into one server after-all... what ya think?
Com-on mods ..."STICKY" this !!! ... pleeeeease
Btw , nice work ps2cho .
Easily. When I made this thread I was rocking it on Duron 900MHz processor. Your dual core server would be ballin!
You may have to take the guide past the basic HLDS (aka addons) with a grain of salt as idk how much has changed since I made the thread. The basic hlds will be the same though. Just follow the guide exactly and you won't have any problems
Will there be any gains by using a dual-core machine with 2gb ram instead of say a Pentium 4 with 1gb of ram?
It doesn't give You much advantage becuse You can only use one core with hlds.exe becuse it is not multithreaded application.Will there be any gains by using a dual-core machine with 2gb ram instead of say a Pentium 4 with 1gb of ram?
