- May 9, 2007
- Sydney, Australia
i was serching on google and found a forum and som1 posted that you need a static ip to eneable it
my ip is 10.0.0.138
my ip is 10.0.0.138
Sp4nK said:i was serching on google and found a forum and som1 posted that you need a static ip to eneable it
my ip is 10.0.0.138
ps2cho said:Ok so it is both a router and modem.
Try this: Enable a DMZ on the computer what you want to host with (to find your COMPUTERS LAN IP, NOT WAN, go to start -> run -> type cmd -> type ipconfig and look for IP address) Take that IP and go into the router then enable DMZ on that computer.
If the HLDS still does not work that means a) Your ports are getting forwarded to a 6xxxx range and you need to find out which one it is or b) your ISP has blocked that port.
So first load up the server and then refresh the steam games list and see if yours comes up.
Sp4nK said:how do i enable dmz with my modem
Sp4nK said:nope cant fint it
me thinking of justr buying a new router
cause i go to my friends house and there ip in cmd>ipconfig is like 149.138.142.412 then me chek mine its 10.0.0.1
Sp4nK said:it rekons thats my ip 124.183.165.195
Sp4nK said:ye me tried that b4 still they cant connect
it says server can not connect
Sp4nK said:ohk
just tried that didnt show
me tried to open the ports using www.portforward.com
and the site says mi router does not have enough port space to open
Sp4nK said:ohk thx for all your help ps2cho
i finally got it
me so happy
only 1 more question should do it
what do me set sv_region to for australia only?
Sp4nK said:once again thx for all you help guys
me supprised u stuck with me lol
cheers
ps2cho said:Well I don't run HLDS anymore so I'm just going off knowledge I picked up. A lot of what I told you is networking knowledge really. If you have anymore questions about mods or cfg's feel free to post. I check OCForums several times daily so you can expect a fast response.
Yeh just looking back I made the guide back in early 2005, so 2 + 1/2 years ago
