- Aug 2, 2012
So, I got the EVGA Z97 FTW motherboard, a Pentium G3258, and 2x8GB G Skill Sniper 2133 CAS10. At first, it didn't post at all, and it was the CPU. When I removed the CPU, I found that a corner had been bent. I bent it back in place, and now have at least gotten the motherboard to POST. I now get POST code 55, which means "Memory Not Installed".
I get the same POST code with both sticks in all slots, and also tested a second kit of RAM (Kingston Hyper X 2x4GB 1600 CAS10). Same result. I also had a friend who purchased the same motherboard, who had issues with memory reading, too.
If the motherboard POSTS to the point of "memory not installed", then that gets the CPU out of the equation for issues, right? Which is more likely, do you guys think? Is the issue arising from the CPU bending, or do you think I have motherboard RAM slot issues, now that it actually recognizes the CPU well enough to POST?
