- May 19, 2003
- Kingwood, TX
Kbofwy said:I use the cable ties. I double them up on each fitting with one turned 180 degrees to the other for a gapless grip. Haven't leaked yet.
Exactly. I might go 90 instead of 180, but either way the result is the same. No leaks.
The other thing I do is take a slightly larger diameter hose and cut small "dohnuts" off of it and use them as hose clamps. Clear clamps on clear hose, don't get much better than that
