- Jun 29, 2013
- Houston, Texas
Introduction:
First off I am not new to WC builds although I have not built one since I had my E6600 oc'ed to 4.97 and 2 4870's in Xfire (yea, it's been awhile.) I am getting back into it for my i7 build which currently consists of an EVGA X79 151 Classified mobo with a 3820 @ 4.3 and a Gigabyte 780 I am still playing around with. I've been running it on air but like a true overclocker I have to push it harder. The ultimate goal? Break the benchmarks of course! I am posting this project and documenting it through all phases (you know a normal project) but more or less looking for advice from the community as my build progresses. Also, I am not looking for you guys to wipe my butt or spoon feed me. I am an admin of 2 different very large MMO clan sites and boards so I know how irratating it is for the community. I do know how to use the search feature on the boards So don't worry guys no newbie here
Initial Planning Phase
Basically the goal is to run at least 3 separate loops. To attain the highest o/c I can flow and component isolation is key. This is how it will work:
CPU - Single bay res & 3X140 RAD. Note: I want to try double mounting the fans in a push or pull config. The idea is similar to turbojet engine with multiple fan compressing the air before it reaches combustion chamber.
GPU - Going to eventually run 3 or 4 Gigabyte 780's (wanted EVGA's but as ya'll know no one has them. I got the only 780 that was available in the entire Houston area which was the Gigabyte) I do not want to run these on the same CPU loop. If I run 4, I will probably split them up into 2 loops each with a 360 rad. If one loop a 480 rad. Depending on space, may try same fan setup as cpu loop.
Ram - Single loop running to a single 140 rad. Looking at Gskill 2400 64GB. I don't see myself needing more than that.
All this will be going into either a CM Cosmos II or a Corsair Obsidian 900D.
My line of thinking is that I can run multiple loops and effectively isolate the heat of one component from the other. With high CFM through overkill rad's for the loops I should be able to obtain lower temps. (thinking 'out loud' here)
I have used Danger Den products in the past although they have seemed to all but disappear recently. I am seeing a lot of Alphacool and from what I have read the are a higher end company. AquaPC looks good too. Will be doing more research on these guys.
Build Summary & Notes
Planning Phase 1 Notes
1: Corsair 900D Case
2: 480 - 60MM Rad | 240 - 60MM Rad | 420 - 60MM Rad (Alphacool)
3: Res - http://www.frozencpu.com/products/1...dalone_Reservoir_Maelstrom.html?tl=g30c97s165
Parts List
1: Rads 2 http://www.frozencpu.com/products/1...Copper_Quad_120mm_Radiator.html?tl=g30c95s570
http://www.frozencpu.com/products/1..._Dual_120mm_Radiator.html?tl=g30c95s160#blank
2: Pump http://www.frozencpu.com/products/1...rolled_Water_Pump_-_Black.html?tl=g30c107s153
3: Blocks CPU http://www.frozencpu.com/products/1...on_-_Socket_LGA_2011_21587.html?tl=g30c85s139
GPU 2 http://www.frozencpu.com/products/1...on_-_Socket_LGA_2011_21587.html?tl=g30c85s139
4: System Monitoring
http://www.frozencpu.com/products/1...0_-_500_mbar_53135.html?tl=g30c229s1796#blank
http://www.frozencpu.com/products/1...rmal_Interface_Controller.html?tl=g30c229s882 (If Implemented will change pump choice)
5: Fans / Controllers / Accessories
10 http://www.frozencpu.com/products/1...an_-_2_Pack_CO-9050014-WW.html?tl=g36c365s936
Distribution
http://www.frozencpu.com/products/1..._8xWay_Block_MMT-PCB-6-83.html?tl=g47c121s424 (Need to find out how to adjust power from the molex to the board to control all connected fans simultaneously)
Notes in progress.
The PC (current Config)
First of guys. Enjoy:
http://www.3dmark.com/cg/554272
Don't make fun of the desk....
Yep. I'm getting there slowly but surely.
Parts List
Distribution
Notes in progress.
