InfiniteImp
- Jul 11, 2017
Hey everyone, I've run into an issue on which I'd like to get some opinions. I just upgraded from a couple of GTX 980 Ti HydroCoppers to a single ASUS Poseidon 1080 Ti and I've noticed that my flow meter is is running a lot more slowly. I'm running 1/2" ID (3/4" OD) tubing and I have to assume the decrease in flow is because the ASUS card has a smaller channel and is aimed at people running smaller tubing. I'd like to get my flow rate back up and I'm thinking of adding a sort of bypass to the video card and adding a y-splitter to recombine the flow once it's gotten past the video card.
My question is, with this bypass implemented, will the video card get sufficient cooling? In other words, will enough flow make it to the card?
I'm attaching a picture to help illustrate this. This is a work in progress so it's a bit of a mess, plus I have no artistic skills so I hope it makes sense. The red lines is where I want to run another piece of tubing and join it to the existing exit tubing using a Y-adapter.
Thanks.
Thanks.
