- Nov 15, 2010
- Livingston, Scotland
I have my my CM690 for 3 years now, and I love the case, however apart from a side panel mod, i have never done anything more to the case, so ive decided now its time to make a few changes to my setup.
Plan Of Attack
[*]Move Hardware to new case
[*]Strip Down CM690
[*]Paint Case Internals
[*]Make Side Blower to help exhaust hot air from psu + GTX460(not in use with new hardware, no need)
[*]Cut grills
[*]Install Corsair H100/other h20 cooling
[*]Cable Management
[*]Transform Internal to external DVD drive
[*]Install Fan controller
1. Moving The Hardware
First thing to do, was to move the hardware over to another case temporarily so that the system was still useable and safe.
Yes, that hardware is going into the red case...
My Temporary Power Switch
Hardware installed and system up and running, And folding away again.
Currently only running with 1 120mm cpu fan, will be installing a few more tomorrow once ive cleaned them up. 100% load temps are between 42C and 47C @ 2912 MHZ (416*7)
2. Case Stipping
Getting the Thumbclips for the pci slots out wasn't the most fun activity i've had to do.
Also whilst i had the case apart, i've decided to cut the plastic out of the top panel seen as its restrictive of airflow and blocks fans. The area marked in red will be cut out.
I am also temped to cut the grills out from the top fan slots however i do not know what benefit this would have, however i have seen ALOT of CM690 mods in which this has been done so if anyone could inform me of a reason to do it, it would be much appreciated.
