So I finally thought I had all I needed [yes, been ordering in drips and drabs] to finally start plugging away at my water cooling loops. I went to install my XSPC dual bay reservoir and the cutouts in the middle [of the sides] of the res weren't big enough to accommodate to metal ledges from the case. I took out the dremel and got the ledges down and the res....fit in with some elbow grease. A little more than I was comfortable with. then upon fastening up and putting the face plate on, the res is crooked! I tested my dvd writers and fan controller in the same spots and they are all flush with one another, so I think the res is faulty and am currently trying to RMA it [but might not have success since I am passed the 30 day return, unless it truly is a faulty product].
So I have been rethinking things a bit and possibly scrapping the bay res altogether.
I really like the way the
iandh cylinders looks, but most likely will not be able to fit two, where I want to in my case. So that has me thinking...what if I ran one large loop with that res and a
XSPC dual top for my pumps [along with my 2 rads]?
OR
Staying with the two loop idea and either mounting two
XSPC Acrylic Res tops or two smaller
EK 100 cylinders on
UN brackets, which I would be able to stack vertically in my case.
1. Option one I'd just need the IandH Cylinder res and the dual pump acrylic top.
2a. Option 2 with the acrylic res tops, I'd need the tops and brackets.
2b. Option 2 with the EK cylinders, I'd need the cylinders, single acrylic tops and
I've seen, what seems to be, quite a few pics of option 1 on systems that have way more hardware than I do [then again, no idea what kind of OCing they are doing, or not doing].
I know much of how things are setup are personal preference and what one is trying to accomplish, but I just need a nudge or sorts. Some feedback on what the more experienced would go with if they were in my shoes atm. I am only looking for a moderate overclock atm [although sure I will push a bit more once I get my hands dirty in it] and would most likely add a second 5870 down the road.
Thanks guys.
J
