So I have been messing with GPU overclocks. These ti's do not move as quickly as the 1080 I had. I ran my 1080 ftw hybrid at almost 2.2ghz. Struggling to keep this ti stable at 2025 sustained. If I up the offset to about 82 it will stay at 2012mhz and my memory at 5999. But I just spent an hour or so playing the division and looked at all my temps with gpu z and the icx memory 3 and icx power 5 are scorching at max temp. Memory 3 had a max of 95c and power 5 had a max of 127c. This sounds extreme. Max gpu temp of 52c I have attatched a screenshot showing gpu z with the max temps displayed. It also shows my gpu oc settings. Voltage max, power max mem offset 496, gpu 80. These two temps really concern me. Is this normal? I don't really know what is actually being measured for power 5 but I don't believe it is safe having memory temps hit 95c. I never checked the temps at stock settings. I will do so and repost later. I noticed about a 15 fps increase from this overclock in the division.
