LeperMessiah
- Sep 26, 2012
I've been reading a lot of guides and watching videos and read many threads and I have some specific questions I would like to clarify if anyone is up for the task.
First off my specs:
Intel i5-3570K 3.4 Ghz
Gigabyte GA-Z77-D3H board
8 GB Ram
850w Power Supply
Asetek 510LC Liquid cooling
GeForce GTX650
Just to give you some sense of my goals: I'd like to clock it up to 45, and mainly I'm a casual gamer and photo editor, but mostly the computer will be doing simpler tasks.
Questions:
1) What is the downside of using the Intel TurboBoost? As I understand it, setting the cores to something like 45/45/44/43 is more power efficient and it will only run it up to 4.5ghz when there's a demand... the rest of the time (like for browsing) it will run closer to 1.6ghz. Also the voltage can be automatically adjusted, specified by my Offset Voltage (eg. .015). The alternative is having all of the cores running, say, at 4.5ghz all the time and the voltage being at a fixed rate (unless I change it). I'm a casual gamer, so which is better, using TurboBoost or using separate fixed profiles for gaming/photo editing and for more basic computing.
Subquestion: Should TurboBoost OCing be benchmarked in the same way as manual OCing? For example, would I start TurboBoost at 38/38/38/38, benchmark it, and then increase it incrementally from there?
2) I've heard that Prime95 is too aggressive for Ivy Bridge processors and a program called AIDA64 is better. Is that true? What about IntelBurnTest?
Subquestion: Some people say you only need to benchmark for 15/30 min, some say an hour, some say 12/24 hrs. What gives? lol
3) Is Gigabyte EasyTune useful at all, even if just for benchmarking different profiles? I haven't heard much anything good about it, but I like the idea of changing settings in real time without the need to reboot.
Sorry for being wordy, I get the sense that there is a shorthand for what I'm describing here but I don't know the jargon, lol. Thanks!
First off my specs:
8 GB Ram
850w Power Supply
GeForce GTX650
Questions:
