I bought this 1U power supply for use in a custom designed SFF type enclosure. The problem is the 2 -40mm fans that came with it, spin somewhere around the 10k rpm range (what it sounds like at least) and they are too loud for my current design. Since I will have the room in my case, I want to know if you all think it would be ok for me to remove the two fans and just cut out a hole for an 80mm fan to be attached to the bottom. See pictures for details.
So, question #1 - is this ok to do? I plan on mounting the fan on the outside, so it shouldn't interfere with anything.
Question #2 - if I do this, should I block off the hole where the current intake fan is, and just have the 80mm exhaust out the back? If I leave it open, it shouldn't have that much of an effect on my case temps. My main concern is keeping the power supply cool.
The pics:
The pics:
