I was wondering if it was possible to fit the 2-342 horizontally across the top of the chieftec dragon mid tower. I kind of noticed that there was about 2 inches or something between the ps and the roof of the case but I didn't really factor in fans/shrouds and all of that.... Has anyone put a 2-342 across the top of their case?
Another thing I was wondering was if I set all of my fans to intake (2 80mm in back, 1 120mm in side behind motherboard, 1 120mm in bottom front) and then set the radiator fan at the top for exhaust would this yield better temperatures then just putting the radiator at the bottom front? This idea was taken from another post but I think they suggested not putting fans on the radiator at all.
yeah... also I was curious on whether or not having the order be
fan->shroud->radiator pushing air outside of the case
would be better than
radiator->shroud->fan pulling air outside of the case
Just a couple of things I was wondering before I decide to return this dtek procore before the warranty thing is up.
