- Nov 10, 2003
- Oregon, USA
raptors are sweet. definitely get one =)
vinny77 said:i did memtest 86 on 3.3 ghx i couldent get it up to 3.5 idk whey i didnt have the patients but i ran it for 15 min and there was no errors
mattspalace said:If your HDD is 4200rpm, then I highly recommend getting a 7200rpm drive. The difference will be HUGE.
Albuquerque said:
If you don't have the patience to wait, then you need to stop overclocking. Seriously. You will do a LOT more damage than good if you simply don't have the patience and just start running the machine as hard as you can. It would be something akin to not having the patience to change the oil in your car while running it pedal-to-the-floor every time you drive it.
Eventually, it's going to spin a main bearing and sieze the motor.
Same thing goes for your computer system. If you paid much attention to the CompTia classes in your signature, I would assume you already know what I'm telling you. There is a certain amount of time you must invest in order to assure proper operation of your system and it's different subcomponents.
If you don't have the time to spend, then you really should put everything back to stock speed and run it exactly as the manufacturer intended. When you buy parts, they are exhaustively tested at their rated speeds and are guaranteed to work there. If you personally want more, then you personally must put in the time to do your own testing to ensure they work.
The 2.4C that I have running at 3.45ghz in the background didn't START there, it started at 100% stock settings and worked it's way up. Of it's six-month lifespan, it's probably spent three whole weeks of it's life doing nothing but testing. That meant I had to play on my laptop for a while, or go work on the car, or go clean house, or whatnot while waiting. Same exact thing goes for the 3.0C in my signature...
But I waited. And so should you.
