Mr. $T$ said:You'll need more power, and heavy cooling if you don't have it yet. The gains for a prescott happen at the higher 3GHz range however little is noticable. What you will see is higher temps and a hotter room. Right now the prescott is not worth it, however fun the tinker with if you're that type of guy. Just right now .09nm has no advantage, not faster, not cooler, not more efficient.
Chocobo said:
You think i should wait for the new steppings to come out?
yes but in small amounts.its the MO stepping and a few threads here about them.Chocobo said:So are the new steppings out yet?
hope you have a seperate psu for the pelt.Chocobo said:Well what do you mean by the mosfets? like the cooling on the max3 with the otes? cause i have a max3. Ok so i need a better PSU and i have a pelt. Will all this do?
