Nice o/c for a XP1700 on air.
Is there any way to bump your vcore up a bit more to see if you can go any faster?
Your +3.3v rails looks very low. The best way to check your rails
is with a multimeter. You might want to invest in a more powerful PSU. Looks like the one you have will most likely be the bottleneck
in your overclocking to faster speeds.
Looks good to me. I have the same chip and heatsink. My temps and voltages match yours. My scores are a little lower because I'm only running 170x13. I can't believe I forgot to try REDUCING the clock multiplier. Thanks for reminding me. Now maybe I can crank it up more.
By the way, are you able to up the VCore over 1.850? Mine won't boot if I do. Just curious.
It's A 2100 0302 maxima and I have a antec true 430 the 3.3 rail is my ram voltage the MBM% read the 3.3 as the voltage going to the ram along with the monitoring system.
I can get the vcore up to about 2.025 and then if I run prime the system reboots after a few min's.
