My first post to these forums but I have been lurking for some time.
Based on various independent information sources I decided to try my hand at overclocking.
I selected the following
Asus P4C800-E Deluxe
Antec True Power 430W PS
Intel 3.0C (Retail, got an SL6WK L348A652, luck of the draw)
OCZ 3700 Gold Rev 2
Zalman 7000A-Cu Heatsink
Artic Silver 5
Now I will mention that I am not going for the highest possible overclock, I just want to hit the specified maximum FSB for my RAM at 233FSB. I figure I am doing pretty well at what appears to be the average 3.0C overclock. For me it is a tradeoff, I want to keep power and heat as low as possible, but get slightly better performance than what is available today stock.
I had the system for a week before overclocking it, to let the Artic Silver cure. Played games pretty steadily on it for extended periods, but as the AS site said gave it periods of cool down.
On monday though I decided to overclock. I had no problems stepping from 205-210 and now I am running at my target of 233 and am performing Prime95+Folding@Home tests plus my own regular gaming use.
I did have a failure of Prime95 last night at the auto voltage setting so I increased the voltage to 1.6 as a first step. Then I had a game crash tonight so pushed it to 1.625, then a few hours later another crash to desktop. Now I cannot of course rule out the game just crashing, it is generally pretty stable under my old system(AMD 2400+), but the occasional CTD is not unheard of.
To be sure I am running the Prime95+Folding tests to get a more accurate read.
My settings are the following (otherwise I run the defaults)
233FSB
1.625Vcore
2.75Memory Voltage
Spread Spectrum (disabled but had it enabled prior to this last change)
That is about all I have tweaked...memory is all auto as I am happy running it at its default settings. My goal is to stress the processor, but have plenty of flex left in my other components.
Under load I run
1.488 VCore with occasional increase to 1.504 (~2% flux)
52 Deg C CPU, 35C Motherboard
According to the poll on this site I am just above what most people have for temperature under load. I am pretty sure I can shave a couple of degrees of that too, just need to make some minor cooling adjustments. Keeping the system relatively quiet is also a goal.
I am kind of curious about the voltage at load. From what I can tell this is the same voltage under load I got when the system was running at spec 3.0C with default voltage. Before I over volted a bit manually in the bios I dropped below 1.488. Does this seem reasonable?
OCZ 3700 Gold Rev 2
Artic Silver 5
233FSB
1.625Vcore
2.75Memory Voltage
Under load I run
