- Feb 21, 2009
- Phoenix, Arizona
Hello everyone!
Just curious. I have a 3200+ barton on an Epox 8rda3+ board with 3 dimm slots. board can run a fsb of 400. I have 2x1 gig sticks of ddr400 pc3200 OCZ platinum EL and also a 1xgig stick of OCZ titanium pc3200 ddr400. Should i run all 3 gig on the board? im running 32bit xp pro as an os.
I heard rumors that there was some issue w/ xp not seeing the 3rd gig and the ram wouldnt run as fast as the 2x pair. All the ram is unbuffered. If I do run all 3.... is there a speceific order as to which ones are in the slots? 2 of the 3 slots are closer to eachother than the other 1.
Any help would be great!
Thanks!!!
Oh btw..i just picked up a thermalright slk-800 off of ebay and will be doing a slight OC on my rig. What's a good fan for that slk? noise isnt an issue as i have a thermaltake xaser II case and it's nice and quiet with ok cooling. i'll be modding the case with a 120mm fan in the top and maybe some higher CFM fans all around. seems it's difficult to just look at cpu fans without the actual heat sinks attached on newegg. Will case fans work in that department?
-Sean
Thanks!!!
-Sean
