Hello guys, I wonder if my rig is enough using Cooler Master 500W?? My specs:
Phenom II X4 955 BE (not overclocked)
M4A77TD PRO
XFX 4890 1GB
2 Hard disks
3 12mm fan
CPU cooler: Zerotherm Nirvana NV120
1 Optical drive
thx
Well yes, it has only 1 6-pin connector, so the rest i took from 2-sata power connection, is it okay with the connection??
The spec for my PSU is 36A (360W), 22A and 25A for 3.3V & 5V (165)respectively...and say it has 80% efficiency... I already counted and the result was 347 for recommended PSU wattage, but i wonder why my screen it's like refreshing or blinking but really fast...is it caused by the lack of power??
Power rating is on the output side (how well it can convert wall power to power your computer can use). A 500W power supply at 80% efficiency will draw 625W from the wall to supply 500W at maximum load.I already counted and the result was 347 for recommended PSU wattage
No, and the screen is not even connected to the power supply.but i wonder why my screen it's like refreshing or blinking but really fast...is it caused by the lack of power??
