- Jun 7, 2011
...at stock (manufacturer OC) clock @1100/1200, no changes to the clocks made.
But why it was so hard to find out i will explain:
First, when i was finish with the build i was starting up the machine and everything worked proper so far.
There was only a few minor flaws such as:
1. Picture not centered. Not the first time it happens on a 7000 series, i dunno why, but i could fix that issue using a AV receiver between PC and TV, so the Receiver can fix it for me. Or i simply wait for the driver to kick in, and the driver will fix it too.
2. The fan was at full speed from its sound as long as the driver didnt start to work. But it worked properly when driver was enabled (short time after start).
However, for some reason the Windows Index only showed a 7.8 for GPU rating, even when driver enabled. So i found it weird because even a 4000 series could become such a rating and any GPU stronger than that will hit 7.9. Another thing which seemed weird: The GPU Z tool had a very hard time to readout the GPU, there was close to no stats when comparing to my other 7000.
In order to find out the truth i used Unigine Heaven and wanted to bench, so i may find out if just Index screwed or a real issue. However, in the middle of the Benchmark the screen was going black and the PC completly stopped working. All of a sudden, it was going that fast, it feels like something exploded in the middle of the bench.
Troubleshooting the failure:
Now i wasnt sure what happened but PC didnt start anymore, it kinda died. First thing i got in mind is that the PSU may have stopped working because the GPU for some reason was underperforming and maybe it became to less juice. As soon as the GPU was drawing even more juice the already weakened PSU may be blasted because of a manufacturer failure. At least it was my theory... i wasnt sure of course.
Luckily i own a PSU with a self check (Corsair 1200i) and i used the self check which failed on me. So i had in mind the PSU is defective.
Some other time, i already had in mind to get a backup PSU mainwhile, i found out the hard truth:
Because i was kinda unsure if that is truly the case. Corsair and digital PSUs? Its kinda the Ferrari of hardware, its very rare having them die. So with all my doubts, i checked out the Corsair forums and i suddenly noticed a important hint: In order to self check all the cables have to be plugged out except power cable of course. I had in mind the PSU will just ignore the cables when self checking. But finally it could be different, i just didnt think about when i was in such a "rage of loss". I was not in the mood to read the whole guide, so i just checked the first words from self check entry.
So i made another self check, this time without cables attached, and it worked properly, having a green light.
Leading to the question, but why didnt the PC make a single move?
The only thing possibly happening, in term PSU is fine, seems to be a busted up motherboard, and i was kinda frozen because of that shocking insight. It would be the hardest stuff to fix, thats certain, especially because there is a huge (usualy used on many full towers) and challenging cooler attached on a very small mATX board and case. That stuff is by far most challenging to build so far. I will have to remove the 2 backplates with 16 screws in order to acess the MB freely, remove cooler (difficult to acess) and clean TIM, its simply hardest work when MB dies. Its not a usual build, its a rather taxing one and most OEM builders are trying to avoid such stuff, to much work.
However, the truth is still different:
I decided not to trust that feeling, even when the risk is way to high. Prehaps its still the GPU, even when the MB isnt moving a single finger ehm... fan anymore?
I tried reseting the CMOS, prehaps some issue there. I just noticed, every time i used the reset button, the fan light was going on for a fraction of a second. So i made it several times in a row and tried to start up after. After a certain numbers of failed tryouts, it suddenly was becoming alive. Now the PC finally was running again but there was no picture on the screen. I made several restarts and still unable to see any pictures but i was certain that all cables are attached properly. I tried to put in the cables as hard as possible... but just nothing and checked channel of TV.
Could it possibly be a MB problem?!? I decided not to trust that feeling, even when the risk is way to high. Prehaps its still the GPU, even when the MB isnt moving a single finger ehm... fan anymore?
Well, i removed the GPU and was seating my prehistoric 3870 at that spot. A GPU way to old and crazy enough for it still to run properly. After testing out and connection all the stuff, finally i see a picture. The MB was in "initial setup" mode, and i had to enter some command first. I remembered that the same command was requested at the 7870 GPU, when that GPU was inside but only at the debug LED (known as A2 issue). So i was entering the command and finally the PC was booting up properly.
In order to be sure that the MB isnt damaged, i tried to make as much tests as possible. Made over ten restarts but not a single issue anymore. Now the PC is running for over 6 hours already, post was written using it too. Also i made a Prime 95 run which suceeded nicely. Max temp at 74 C after 5 min, with only a single fan attached to the cooler (because to less space in order to use 2 fans on the Phanteks). Even the 74C is far underrated because i still miss 2 active case fans which are not working at that moment (im in emergency testing mode, i dont care fans except the most critical one).
But why the MB completly failed to work and didnt make a single move anymore when the GPU died? I think my logical answer to this is that this board got no internal GPU, not any at all. So it was saved to the CMOS and a very crucial hardware part. On the other hand the GPU was dead, so the MB simply stopped working. The GPU is that critical that the MB apparently needed several resets in order to ignore that module. On the other hand, the GPU may have been turning itself off in such a harsh way, almost like exploding, that the CMOS got some error flaw or something like that, so it needed some time to restore. Thats my theory at least, im not a experienced PC support/tech.
Besides, when it comes to RAM the MB is behaving very nicely, it feels like the MB and the RAM is a perfect match running quadruple at 1600,9,9,9,24, 1T very fast. Such issues can be excluded, there was not a single hint. Bootuptime is astounding too, 18 sec including virus scanner.
Anyway, now im pretty certain that my 7870 Hawk must have died, its almost way to clear, its close to impossible having another failure when all the other stuff is working properly now.
So my 7870 truly died and what else might have happened? Yes pretty complicated story, but thats why troubleshooting is no easy work for many PC techs, i guess.
