- Jan 19, 2006
- Florida
I asked "B" to do a simple test run and post it as well maybe we get a look see before I get it in my hands haha
I'll have to take this result down when I send the card back of course, but for now here's the result of some fairly quick air benching. Stock cooler.
3DMark11 - 11572 marks.
Card wasn't interested in >1200 core regardless of voltage (1.25v and up), I suspect lousy contact between core and heatsink as the cause.
Memory slider maxed out even in AB-X, T&B's going to have to figure out something to do about that, it has lots of volts and clocks left in the tank I think.
That'd be why the standard OCP mod fries MOSFETs, it removes almost all to all current sensing, 100 amps looks like <10 amps and the thing switches to single phase mode. POOF goes the poor MOSFET that has to switch for it.CHiL said:The CHL8225/8 includes the CHiL Efficiency Shaping
Technology to deliver exceptional efficiency at minimum
cost across the entire load range. CHiL Variable Gate Drive
optimizes the MOSFET gate drive voltage as a function of
real-time load current. CHiL Dynamic Phase Control adds
and drops phases based upon load current. The
CHL8225/8 can be configured to enter 1-phase operation
and active diode emulation mode based upon load current
or by command.
Found a partial datasheet a while ago, while re-reading it and arming myself for attacking the GBT 7970OC that is next on my mod-plate (it has all seven (6+1? 5+2?) phase slots occupied, reference only uses six (5+1), I ran across this tidbit in the bragging section:
Is there a easy work around on that?sounds like thats the answer to the big cook out!
