- Jul 5, 2004
- Santa Ana, Ca
Have you tried seeing what the temp is in the Nvidia driver settings instead of Riva tuner?
They read the same sensor in the same way.
Viper
Pretty sure it's just poor design of the cooler not managing the heat correctly. I put a 1200cm fan blowing directly on the ambient heat area out the back pushing major air through it and now Im looking at 70c load temps steady and 49c ambient.
I don't think the heatsink is too bad or the paste was on wrong, I just think that the cooler has too much venting in it instead of getting rid of the latent heat. Slowly gets hotter and hotter heating itself instead of just pushing out the air like it should. Guess I'm going to have to shell out some cash for a new cooler that isn't trash and find a way to place my spot cool to be more efficient.
Temps still seem a bit high for the massive amount of currernt airflow it's getting though, you think I would be better off RMAing it first before purchasing aftermarket cooling?
VJ, why do I need 1000cfm from a huge fan to get to "standard" load temperatures? Even when the side is off and I bring in "slight" air from the front and keep the pressure nominal, I am seeing 87c load temps that continue to rise. It is only with massive air movement where I get rid of ALL of the hot air do I see any real difference in temperature change.
I don't understand why my 2900XT ran cooler than the 8800ultra at "higher" clocks and much higher power draw in the same exact system.
Thanks VJ, that is what I assumed also. There just seems to be a ridiculous amont of heat coming from every corner of the card without a huge fan blowing on it.
It's fine when it just sits there, but if I bring it up to any type of load, it just gets hotter and hotter and hotter, even with the side of the case off. Once I take off the load, it never cools down unless the big fan is on it.
I feel safe with my decision now to RMA, I figured just the same that if the 2900XT was fine (although loud fan) then the 8800Ultra should have been the same or better given the amount of power the 2900XT uses.
Your case temp is over 50c? Either thats wrong or you have an oven going. My case temps never go over 38c and thats when its hot in the room.
I was about to say that but you beat me to it.one thing i noticed is that when you replaced the tim on the gpu you left the seemingly torn ram thermal pads in place and i assume just re attached it like that? ive been reading alot of people have to replace the thermal pads when they do this or else the ram doesnt make proper contact with the heatsink thus artifacting. maybe this is the cause of your new artifacting?
vixro...
my card runs about 60 idle and 70s up to 80 under load at stock too as are many many others.... case open or not
http://www.zalman.co.kr/eng/product/view.asp?idx=289&code=013
buy that bad boy and i bet your temps will go down ALLOT
be sure to buy some arctic silver paste that will also help.
yup I think something is definately up with the card. Just for the hell of it, I tried to find out at what point mine locked up during the ATI stress test and it was rock solid all the way up to this point (core clock). This was at 80*C core temp according to Riva. The heat sink was really hot too.
My guess is that if your heat sink isn't hot to the touch, there's something up with the temp sensor.
