Current system:
Mobile 2500+ OC'd 2.46Ghz (11x233)
Zalman air cooled... Idle 41C, Full load 46c
NF7-S 2.0
120GB ATA 100, 8.5 seek time Seagate, w/8MB cache
512 MB PC3200 (Corsair Value Select)
Windows XP SP1
Direct X 9.0b
Latest Cat drivers
Using onboard sound and LAN
Sony CRX230E CD-RW
Sapphire Radeon 9600Pro (core 400 & effective DDR memory 600), running at full 8x and full performance.
I'm getting a little over 2800 score on 3DMark 03, and 10,000+ on 3D Mark 2001SE.
If I overclock the core to 450+, and DDR memory to 660, I get about 3000+ 3DMark 03, and 11,000+ on 3DMark 2001SE.
Something wrong here with the scores?
Another thing I wanted to point out is if I overclock my system and overclock the card as noted, I can't even get 3DMark 2001SE to start unless I up the voltage in BIOS to the AGP card to 1.8v. Otherwise I have to set it to almost default speeds to run it. And 3DMark 03 crashes halfway the same. This is also true if I overclock the card even slightly (i.e. 420 core, 620 DDR). Bad card maybe? No artifacts when I overclock though.
My Windows 2000 system (in my signature) is able to get 3DMark 2001SE scores as noted in the signature (sig changed)... with about 9-11k, but only 1,500+ on 3DMark 03 (possibly due to it not fully supporting DirectX 9+?)
NF7-S 2.0
Windows XP SP1
Direct X 9.0b
Latest Cat drivers
Sony CRX230E CD-RW
