- Dec 21, 2009
Hello All
I'm helping my brother setup a server he has. The server has a 3Ware 9690SA Hardware RAID card, and it has 4 x 2Tb 5400 RPM Samsung Harddrives.
When I boot into the 3Ware BIOS, it recognizes all 4 drives, no problem. What he wants to do is install them in RAID 10 for a 4 Tb mirrored volume for performance and redundancy. When I try to create a RAID array with the 4 drives, and set it to use RAID 10, it only allows me to utilize 2079 Gb (1/4 x 8 Tb), which is half of what I would expect for this RAID config.
Assuming I go ahead and allow it to build the array with this volume, we can go on to install Fedora 14 with no issue, but still only 2 Tb are available.
This is our first time setting up a RAID array like this, so I'd appreciate any advice anyone can offer.
I've also tried enabling Auto-carving to insure that I have support for physical volumes larger than 2 Tb, but to no avail. With the version of Linux we're running, and the RAID card he's got, it should support greater than 2 Tb PVs either way though.
Thanks!
Thanks!
