9800 pro scores Good/Ok/Poor
p!ktu]2e_1
I get 5625 in 3dmark03. I hear that it is okay, but I wanna know what is a good score, an ok, and a poor one.
Will overclocking give me 400+ extra marks?:confused: :confused:
my scores in my sig. its a 9800np even though it says pro in windows for some reason.
It very easy to run some compares on the ORB using different search strings.
Try a search for all drivers/all CPU/ with the 9800Pro. That will list the top score for that card. Then match or vary your CPU speed/GPU speed to suit your need's.
i have my 9800 pro water cooled and think i have a low overclock but what really made like a 100 - 150 point difference was using the omega drivers...cant find my compre url atm seems as the link is down :( but i get 6500 aprox ....check these drivers out:D
What are the best drivers for 9800 omega or ati? Im using 3.9 by omega, they seem ok... :confused: i guess...
I think you could get a better stock score m8. I was closer to 6k stock.
Make sure all your sliders are set to performance and disable anything you have running and also set it to realtime {mark03 that is)
I would bet your ram is gonna do 370 or so with stock cooler.
I did everything and now I get 5623. You are saying that I should be getting 5800+ stock??? Is there something seriously wrong??:temper:
my stupid little sapphire radeon 9800NP won't go much faster than 440 core and 385 mem (artifact free) so I only get about 6000 in 3d mark 2k3. I guess thats what i get for having Samsung 300MHZ rated ram. hmmmm... maybe I should upgrade my cooling from stock.
LOL, that was the best $250 i've ever spent:D
