- Aug 30, 2004
- Santa Barbara, CA
Work in Progress:
Introduction:
Much of the information available in the enthusiast world regarding recapping a motherboard falls into two categories:
- A recap was done because the stock capacitors failed, rendering the motherboard inoperable.
- Anecdotal evidence of "a higher overclock" being obtained was the motivation.
In other words...
I basically have a few tools and I'm going to mess around with the setup as and when I can think of something new...
Aim and scope of this experiment:
If you guys know me well enough, you would understand that I don't like wishy-washy speculative BS. So let us get down to a simple outline of what I'm trying to accomplish.
- Use signal quality analysis as a metric to gauge every proposal being made.
- Study the impact of ESR, Voltage rating and Capacitance on CPU power delivery.
Method and Tools:
For this experiment, I will be using a Gigabyte S478 motherboard (onboard crapphix), a Textronix TDS524A DSO, an HP 8590B RF Spectrum Analyzer, A Textronix 2225 Analog Oscilloscope and a Silverstone Zeus ST56ZF, some generic crap DDR.
From what I have read and by scanning numerous Intel VRM design guidelines, Buck regulator datasheets, the issue that comes up over and over with regards to CPU stability is the amount of ripple/AC in the delivered power. This seems to depend on many factors like the inductor current, number of phases employed and the switching frequency.
Bulk capacitance is said to play a very important role in minimizing the amount of ripple current being allowed. Bulk capacitance includes the MLCC (Multi-Layer Ceramic capacitors) chip caps you see in the LGA775 socket for example, or directly on the CPU die and the ones near the phase inductors outside the CPU socket.
I will be looking at the effect of these bulk capacitors, more specifically the bulk cans outside the CPU socket.
Questions that will be addressed include:-
- What happens when I change the capacitance value?
- What happens when I add more capacitance?
- What happens when I replace 6.3V 1500uF caps with 4V 560uF Sanyo OS-CON's?
- What is the bandwidth of the AC riding the DC?
- How do results change if I use an AC coupled probe over an uncoupled probe?
The setup is very simple. I've put a shielded cable in a vacant capacitor spot next to the inductor. This capacitor shunts the inductor to ground providing a low impedance path to the AC signal. So, this is going to be one of the spots of choice to test the effectiveness of all the shunt caps. The idea is, if the signal really noisy at this spot, then the capacitor bank is doing its job of shunting out AC to ground. So, I expect to see an INCREASE in noise if better caps are used.
If anything to the contrary is seen, my assumption of the regulation layout will be proven wrong and at that point I'll move the test point directly over the leg of one of the MOSFETS.
The board itself is pretty decent, with Rubycon, Nichion and Sanyo Aluminum Electrolytics. The only sore thumb being a pair of garbage OST's on the CPU VRM side.
