- Nov 8, 2001
borging
I've tried this on 2 machines and neither is getting gromacs. I'm going to give them a chance to get a few more WU's and see if its just bad luck or a if its a config problem. I edited the reg key correctly.
Could someone who's done this tell me if the fah.log file shows -advmethods and -forceasm when the machince first starts? Mine only shows -service.
Edit: I changed another reg key in the same path. This one called parameters instead of applications. It said only -service, so I added -advmethods and -forceasm to it. Now my fah.log shows those flags and I am getting gromacs. This seems critically important to me and I think borgers should check the logs on their machines to make sure the gromacs flags are working, since gromacs is generally 1.2x - 4x the point production rate of tinker.
It may have just been the timing and that the gromacs weren't available at at the time, but I don't think so since I examined the top of the fah.log file after first installing the service, changing the reg keys, and rebooting. No -advmethods or-forceasm. Then after changing the other reg key, restarting, and checking the log file they were there.
This happened in win2k and in winXP home. I think other borgers need to look into this, especially the P4 borgers!!!!
