Here is the deal guys, I cannot run the program as a service if I enable any flags (-advmethods –forceasm).
If I use an existing install and use the fah_service_installer to install my previous 3.25beta console app, everything works perfect.
UNTIL I add the reg settings to either "application" or "paramaters" into the registry.
Without -advmethods –forceasm in the paramaters key or "path/to/file" -advmethods –forceasm the client works fine, loads fahcore_78.exe and begins folding.
But if I modify any of the keys and add -advmethods –forceasm to them, all that the service starts up is fah3console.exe. It doesn't load the core and the program uses no cpu time. The program is on but it does nothing, and it doesn't write anything to the log file.
I've tried only used 1 key with both of them, using use_reg=on and off in the client.cfg, and pretty much tinkered with anything I can to no avail.
Whenever I delete the modifications to the reg key(s), the client starts fine and starts folding, but as soon as I add any of the keys to the reg it doesn't work.
Any idea's? This little dos window is annoying
