Is there any Lian Li case with std. or opt'l clear side window, in Height (my only and nagging concern) between the tall end PC-65B and the short microATX PC-30 type, and which does have the typical H mounted psu? Maybe a 3+2 case.
I have been searching for a new case, because I want a black one now. I want simplistic design without colours - a little silver is fine. Height is the design issue I am wrestling with with all my might right now; I want to get the height down to the lowest possible, while still having the ps mounted rearward Horizontally above the mobo. Originally my though was to be quiet, but everything else being equal the difference between a Antec SonataIII can't be much. My current case are 42mm & 44cm high, and the mobo & ps fit the way I want, H above. Lian Li seems to be the only choice for me: why not the Lamborghini of cases - I've read several data sheets, but theres too many to keep track, and versions. The runner-up type to the Lian Li is the cheapest case, $50, and take out the ps! There are various things you just can't get around. You can take out a front drive bay for example. The Lian Li PC, PC-30 is mini tower 36cm high, but it has a Vertically mounted ps requirement. Then there is the PC50, which has one more front 5-1/4" bay (to 3) but then is only a little bigger at 38cm than the microATX PC-30: it isn't quite a mid tower, but AhhH, the ps is mounted V along the top side of the case where a window would be, right in front of a cpu & its cooler.
I need to ensure the fitting of mobos in the future will not be an issue. Even the micro PC30 allows standard ATX form factor mobos, as any vanilla or premium models today are (12x9.6"). The removavle mobo tray I hear is awesome, but no affect. Top fan is not an affect. The thumbscew possibility is not an affect. Removable HDD, ps, or other tray is not an affect. I do not care about 2 front fans vs 1 F fan. The L/M/H fan switch inside is a nice touch, but not an issue, especially a possible external type. I have now determined I will get a case with a side window. I will not spend more than $200. I want a case I will be able to get a minimum of 1 DVD, 1 floppy, 1 (blk) 3-1/2" fan & light cntrlr, 3 HDDs inside and all them seem to do that. I may never be more than a GTS320 kinda guy, so the GTX video card length may not be an issue. But I may keep the case for a lot of future systems, and don't know how big vid cards and mobos may get. In this respect I am most worried about the vid card fitting.
The PC-65B is my closest choice, the one I'll get unless. It comes with (clear!!) window std. (some models alow optional at purchase or extra after), removable mobo, HDD, ps, and other? trays, thumbscrews std (not necc'y w/ others), 2 F, 1 R, 1T fans, 2 F USB ports, 2 F fan inside L/M/H ctrlr, but it is 2" to 3" higher than my current cases. Therefore, fit wise, it'll be good forever, and it looks awesome, even the silver bolts around the window. It looks like a monolith-ic stealth bomber. But its -4-5" higher than it needs to be to fit the mobo down and ps H mounted above up. I'd like to chop it down, remove a needless front bay (3+2 is fine). Anything come to mind. Only Lian Li, since the PC-65B is too hard to beat.
heres a pic of the PC-65B, one click down
http://www.burnoutpc.com/modules/smartsection/item.php?itemid=228
