- Nov 27, 2005
Hi,
Tomorrow I will either be ordering an Opteron 165 or an X2 3800+. I'm leaning towards the opteron because of the l2 cache and because I want to get into overclocking. I will be using a dfi lanparty ultra-d, which doesn't officially support the opty but I've heard a lot of people say it works fine.
Is there anything I should know before I decide to buy the opty instead of the 3800+? I've read that the extra l2 cache won't help that much, and that the 3800+ can achieve decent overclocks in addition to having a higher stock speed and a 10x multiplier. I have some more questions...
I can't afford any good memory right now, but later I was thinking about getting the ddr500 G.SKILL Extreme Edition 2gb. That's really expensive, and if I want anything higher than 2.25ghz (which seems low compared to what others are getting, although I would like leave the vcore alone and will be using air cooling) then I will have to overclock it... the only reason I was thinking about ddr500 ram is because I wouldn't have to oc it. Would I be better off with 2gb of good quality ddr400 ram that I can oc to over ddr500, or will I need a divider for anything higher?
Is the RAM I mentioned above just factory overclocked ddr400 ram?
Sorry if this sounds like I'm just rambling. I have a lot of questions/doubts but I don't really know what to ask. I guess I'm just looking for opinions, experiences with either of these cpu's, etc.
