DaveB said:I had two SK6s which fit nicely in my A7M266-D. You can install quiet 80mm fans by simply installing them diagonally and using the standard fan clips. My two XP 1800+ CPUs were running at 1667 MHz with the cores at 1.87V and the max temp under load was 40C. You can pick up the SK6 for less than $25 a piece which is a steal.
