Well first of all my Dual asus had a little problem I think.
I tested both sockets witht he same stepping CPU and the exact same HSF's on both. One was idling at like 41 and the other was skyrocketing up to 60, so I turned it off. I replaced the hotter CPU with a better heatsink, and it was still at a way higher temp! Finally it burned out the CPU and now that I only have one in there, the empty socket is showing up as 34 degrees, and my other socket is at 41 degrees full load. Anyone know why one socket gets extremely hot? By the way, the cooler socket is at 1.85 Vcore, and the hotter socket was running at 1.75 Vcore too.
Wierd Wierd Wierd.
Wierd Wierd Wierd.
