- Mar 15, 2002
- jersey c,i
HI IHAVE A ASUS A7V WHICH MY DAUGHTER USES, WELL HER FRIEND TURNED IT OFF AT THE PLUG WHILE IT WAS ON, KNOW IT WILL NOT WORK, WHEN IT IS TURNED ON ALL THAT HAPPENS IS THA IT MAKES A BLEEPING SOUND LIKE HIGH PITCH LOW PITCH HIGH PITCH LOW PITCH AND SO ON A BIT LIKE THE SIREN ON A FIRE ENGINE (NEE-NORR-NEE-NORR),ACCORDING TO THE MANUEL THIS MEANS NO DRAM INSTALLED OR DETECTED, SO PUT A STICK FROM MY PC BUT STILL THE SAME, DOES ANYONE HAVE ANY IDEAS
SPECS ARE :
DURON 650
256 PC100
4.3gb H/D
CREATIVE VOODOO BANCHEE
CREATIVE 36X CD-ROM
SPECS ARE :
DURON 650
256 PC100
4.3gb H/D
CREATIVE 36X CD-ROM
