- Mar 31, 2005
- Stealing your megahurtz at night
I had gotten this board and have been running it for about a month now. I got it as an upgrade from a FIC AM37, which came with an eMachines, just something to get me by for the time being. Since I have built this system, as only things from old system are my cd-rw and dvd-rw, intenet explorer and Windows Media player seem to have some kind of issue, where they cause the computer to completely lock up, the screen goes black for about a half a second, then it all comes back as nothing happened. I have switched to using Netscape for my browsing, and the problem seems to have stopped. The only OC I have done is the vid, but I used the utility that came with the card, which is not supposed to use any settings that can cause instability. The card is a MSI star-force FX5200 (dont laugh I know its not that great), and runs all my games including doom3 flawlessly. My cpu is Athlon XP3000+ Barton, and ram is 1 gb pc2700 and 256 mb pc3200. I have installed the ram in other ppls systems, and it ran with no errors, and the only programs that I seem to be having this issue with are Microsoft. I'm sure that its not video, since I don't have any problems with games that the card should be having a very hard time running. This is my first Asus board, and so far I like it. If anyone has any ideas, or has had similar problems, I am willing to try just about anything. Thanks in advance. And by the way this is the first system that I have built.
