Hi, was wondering if you guys could give me a hand. This is happening out of the box I have done no overclocking.
Have:
Asus a8v deluxe motherboard, Came with bios version 1009
AMD 64 3500+ (new 512k cache Clawhammers)
1GB (2x512 mb) Corsair TWINX1024-3200C2PT
430 watt Antec PS
BFG 6800 GT (AGP)
SB Audigy 2
80 gig Raptor drive
Basically what happens is it randomly decides to post sometimes. Other times i get "CPU failed CPU test" or "CPU failed due to overclocking" Sometimes I get video sometimes I don't.
Also sometimes it loads up and says CMOS checksum bad, I currently only have one stick of memory in, in slot b1 (tried it in every slot) and the video card connected.
When it does decide to turn on it won't stay on for long and it will shut off. I was thinking it might be a heat issue, I'm using the stock fan that came along with the CPU. I tried some AS5 on it to see if that would help the heat at all, still does the same thing.
Only one time (the first time i turned on the computer) was i able to boot off the windows xp cd, and was getting ready to install windows, then i forgot i needed the sata drivers on a floppy so i turned it off, after that its been doing this since.
Things I've tried:
Flashing up to a beta bios 1011
Resetting the BIOS
Taking everything apart and reseating it.
Tried Booting with only the CPU and motherboard
Tried to underclock the processor
Tried turning HT down to 800 and 200.
I'm sure I tried more stuff then just that to but I was up late last night working with that stuff and don't really remember. Any help would be very much appreciated
Thanks in advance.
Have:
430 watt Antec PS
BFG 6800 GT (AGP)
SB Audigy 2
80 gig Raptor drive
Things I've tried:
Resetting the BIOS
Thanks in advance.
