OMG!!!! my m8 accidentaly put his finger in the cpu fan and one of the fins flew off, the fan started to make a loud grinding noise like it was vibrating very vigirously so i quickly switched of my pc.
I checked the fan and everything seemed ok but the noise was still made II was realy worried i put my case on its side and the noise lessened i cushioned the case with a pillow under it (making sure the pillow was touching nothing on the under side) and the sound can hardly be heard i just need some advice to make sure that nothing more can happen and if i can carry on using my pc until i get a new fan (and also if the cushion under the case thing is a good idea)
Can anyone reccomend a good socket A Athlon XP fan and heatsink preferably a realy cheap generic one anything to replace the one i got.
Also can anyone recommend something to clean the thermal grease stuff of the cpu.
