- May 8, 2004
Hello.
After building my friend an Intel 945G/630 based system, I am itching to build myself a 955x (or even 975) based system. I currently run PC#1 in my sig as my main rig. It would be demoted, and I'd rip the RAPTORS out of it, along with one DVD-Drive - so I'm set on HD's and Opticals for this new system.
I am of course looking at the Asus P5WD2 Premium : http://www.newegg.com/product/product.asp?item=N82E16813131534
Q: What is a good/effective Northbridge HSF for this MoBo? I'll be running a XP-120 w/ the LGA-775 Bracket on the CPU. The other 945 based PC I built runs a bit hot on the Northbridge, so I'd like to actively cool this one...
A P4 640 3.2GHz & 2MB L2 : http://www.newegg.com/product/product.asp?item=N82E16819116197
Some Geil DDR2 533 1GB x 2 RAM (I might "up" the RAM later, but I plan on running 1:1 RAM with a FSB around 275 and CPU Multi set to 14x, so 533MHz should be fine): http://www.newegg.com/product/product.asp?item=N82E16820144336
To be honest, I really have no clue what to look for in a video card . I would like some future compatibility with Vista, but I'm NOT a heavy gamer, and I probably won't even OC the video card. Something with a quiet fan, or no fan would be ideal. 256MB of RAM (256 bit would be nice), and obviously PCI-Express 16x format. Budget for Video Card is around $150. I have been an ATI guy, but I saw the Asus Geforce 6600 256MB, and it caught my eye (no fan) : http://www.newegg.com/product/product.asp?item=N82E16814121199
Any suggestions there?
I'm getting an Antec SLK-30000B case, and I'll be replacing the rear 120mm fan with a higher-flow / variable speed fan and adding an identical fan for the front intake/HD cooler, and I'll be adding a 80mm or 120mm fan to the side panel intake (for the CPU Fresh Air Tunnel). Simular to my current 4GHz rig that runs nice and cool... A lapped XP-120 with a 120mm 110CFM fan will be added for the CPU.
I'm planning on running at around 275FSB (+/-) for a calculated FSB of ~1100MHz, RAM at 1:1 for ~550MHz, and CPU at 14x or 15x (If that is an option???) Multi for right at or under 4GHz...
I'll pull the TWO 36Gig Raptors out of my current rig, and run them in RAID-0 for OS, and also pull a 300 Gig SATA 16MB HD and use it for Data. Plextor 740A for DVD-RW/CD-RW duties on PRI-IDE as Master.
I'll also use my brand-new OCZ Powerstream 520 Power Supply, and put the old Enermax 465Watt back into the old PC.
Sound good? Are there any obvious improvments, suggestions, or "Future-Proofing" qualities to be made for little extra investment?
I'll be ordering in the next few days after a Newegg RMA clears into my Paypal Account. Thaks for any prompt input!
