X
---X---
Guest
What is the absolute highest quality sound format? I don't care how much space it takes up, I want quality
flaming gerbil said:ok here we go. as far as digital audio goes .wav and .aiff are the best quality because they are uncompressed. all mp3's are compressed meaning some data is omitted. some compression schemes are better than others, but none contain as much data as a .wav or .aiff file. there is no such thing as lossless compression, compression by definition is omitting data and therefore data is "lost". now a lot of people can't hear the difference between decent file compression and standard .wav files but some of us can. i can. but then i work with audio for a living and listen acutely all the time. 16 bit 44.1 khz is the standard red book cd specification. 16 bit means the quantization and 44.1 indicates the sampling rate. this means when the analog audio was converted to digital, sixteen voltage measurements (approximations)were taken 44,100 times per second. the bit depth is exponential, so 24 bits has 256x the resolution as 16 bit. and 96khz means roughtly twice the resolution as 44.1. (doubling the number of samples per second) in the real world though differences between 24/96 and 16/44.1 are subtle. it sounds much better to me though, and probably will be the audio spec once dvds replace cds. (cd's don't hold enough data) going to 24 bit increases your file size exponetially and doubling the sample rate doubles your file size. it's expensive to store all that stuff on hard drives. i've have probably 50-60 hard drives sitting in my closet right now. kind of a simple explanation but i hope it helps
Maxvla said:best i've heard is AC3... much superior to mp3 or wav files. but good luck finding songs in ac3 format. they aren't plentiful.
flaming gerbil said:that's different than audio compression. you can't replace the bits of let us say a guitar solo unless you have those original bits on your end of the download. i would like to see a link, cause something amazing might be going on i don't know about.
